Styled Oliver 99 with 6 cly 4 spd transmission
gar68dar
06-15-2007 19:39:12
Noticed allot of postings on how many 99's were built. Heritage Mag indicates a total of 964. (13 built in Dec 52 and 951 in 1953) All were considered 53's. I also take some issue with the use of "HC" in the built sheets to ID all gas tractors. There was a 99 gas built early in 1952 that is not listed HC in the build sheets. Perhaps they started listing "HC" at a later date. Notice the handwriting on the build sheets is the same for everything except the printing of the "HC"...discussion only"
gar68dar
06-17-2007 08:09:59
 Re: Styled Oliver 99 with 6 cly 4 spd transmission in reply to gar68dar, 06-15-2007 19:39:12
It seems they made the first tractor...using the OO as a ser # (518300)with that in mind there would be 14 (not 13)built in 1952 The last one would be 518313 built 12/27/52. Only 5 of these tractor's were shipped prior to Jan 1953(perhaps your's) starting with ser # 518305. Is his 99 gas or Diesel? I have the ship and location dates if needed for that tractor 518313 as well as engine #. Thanks.
good6742
06-17-2007 09:40:52
 Re: Styled Oliver 99 with 6 cly 4 spd transmission in reply to gar68dar, 06-17-2007 08:09:59
I was wrong. His serial # is 518315-C. Must be the second one in 1953 then right?
gar68dar
06-17-2007 11:10:10
 Re: Styled Oliver 99 with 6 cly 4 spd transmission in reply to good6742, 06-17-2007 09:40:52
Ser # 518315C was built Jan 6, 1953(2nd one built in 1953) but shipped "overseas" on Jan 15th 1953. Are you sure about the ser #? Most 99 with 6 cly went "over seas" or South America with a few to Canada and the States. Records indicate this tractor went to Casablanca! Now that would be a rare find if that's yours. I think these tractors are rare to start with. Thanks.
good6742
06-18-2007 19:20:25
 Re: Styled Oliver 99 with 6 cly 4 spd transmission in reply to gar68dar, 06-17-2007 11:10:10
I went and looked at it again tonight to make sure and it is 518315C. I guess it has quite a few miles on in then if it went to Morroco. How did you find that information? Thanks for all of your help and interesting info.
gar68dar
06-19-2007 05:06:54
 Re: Styled Oliver 99 with 6 cly 4 spd transmission in reply to good6742, 06-18-2007 19:20:25
I have a copy of the build sheets for the early 99's after checking out my 99's. These records also show two of the 99's went to Casablanca(518314 & 518315) For additional information and to get the tractor "certified".....Contact Floyd Co. Historical Society in Charles City, IA @ 641/228-1099...ask for Mary Ann..have credit card in hand.(They will offically check it out and mail you an owners certification for that tractor. Let me know what they find out. Good Luck.
good6742
06-17-2007 08:59:17
I'm pretty sure his is the 518313. It is a diesel. We went and picked it up for him out in Oklahoma. We are in Michigan. I'm gonna run over and double check the serial number to make sure, but can you send me the info on it? Thank you.
good6742
06-17-2007 05:27:38
My grandpa has the last one built in '52 if your numbers are correct.
