Oliver Tractor Engine Serial Number
Dan Thornhill
06-14-2007 07:02:28
I have a 1968 Oliver tractor that was converted to a rough terrain forklift. It is in need of a a new distributor / rotar. Where would I find the serial number on the engine & then translate that into the original model number of the tractor? Any help would be appreciated.
SherryS
06-14-2007 12:25:06
 Re: Oliver Tractor Engine Serial Number in reply to Dan Thornhill, 06-14-2007 07:02:28
The engine serial number should be on the right side of the block on the flange at the front of the block behind the timing cover. That engine serial number is not going to tell you anything about the model though. The tractor serial & model number is on a plate under the dash panel. If it's not there, I would suggest providing the casting number of the block and from there we can ID what engine it is.
