88 engine in the shop
DCPULLER
06-07-2007 19:28:30
I'm putting together an 88 engine and am wondering what the horse power will be. here's whats being done, 3 7/8 M & W domed pistons, super 88 crank and rods, 88 head with super 88 valves, port matched 1650 intake, and 1650 carb. I will be pulling stock rpm's in the first gear farm stock class in the 6500, 7000, and 7500#. Cast wheels all the way around and Summit 23 degree 14.9 38 tires. Thanks.
Jerry Thomas
06-08-2007 18:00:34
 Re: 88 engine in the shop in reply to DCPULLER, 06-07-2007 19:28:30
first of all your tractor should not be in the farm stock class have some class and put it in the super farm where it belongs . It is guys like you that discourage a lot of begining pullers. I see nothing to be proud of in beating up on fellow pullers who are trying to have some fun with what they have.
Stu
06-08-2007 18:40:39
 Re: 88 engine in the shop in reply to Jerry Thomas, 06-08-2007 18:00:34
I hope I don't get any thing started, but I don't think running stock parts that have been portmatched is out of line. If the engine was a stroker or had extensive head work that would be different. To me farm stock would represent a tractor that is in field ready condition, and could be used all day without overheating issues. As far as having a 1650 intake and carb, this is a direct bolt-on. Have you ever met a farmer that wouldn't use any part that would work, even if it was for another application? Now if the local rules prohibit non-modified parts that would be different. I hope I didn't step on any toes, this is just my opinion, Stu.
george md
06-09-2007 21:13:16
 Re: 88 engine in the shop in reply to Stu, 06-08-2007 18:40:39
Stu,
I'm on your side and maybe even a little
more hard nosed . I think if it came down the assembly line with a list of items , then that is what stock is , not with half of the gears
missing the pto,and the lift arms missing . The same bunch that want to strip one down for
weight will go to a show and nit pick a restored
tractor for what is not original , seem like a double standard . Around here custom ground cams , extreme rpm,
stripping for weight to get in a class that it
should not be in are the big things . Also bigger valves , port and polish the runners,and cutting heads way beyond limits. I would consider that
cheating .
george
