Oliver 2655 with a 504 engine
Cal Innes
06-07-2007 19:02:05
I have oil or soot (I'm not sure) in the antifreeze. I have just pulled the heads and there is no obvious damage to the gaskets or pistons... they all look pretty good. The curious thing was just before the engine was shut down last time, it had begun to smoke (white smoke)really bad out the oil breather and as it shut down the dip stick blew out of the engine and all 3 valve cover gaskets blew out. I'm not sure what I'm looking for any more... Anyone got any thoughts? Thanks for the help, Cal
Cal Innes
06-08-2007 14:16:03
 Re: Oliver 2655 with a 504 engine in reply to Cal Innes, 06-07-2007 19:02:05
John, I'm on unfamiliar grounds from here on in.If it was gaskets,rings,pistons, I would be fine.... There is no obvious problem with the water pump...What do you suggest I look for? Thanks, Cal
J Schwiebert
06-08-2007 06:42:12
Two thoughts: Did you check the water pump since it is driven by the timing gears. Next thought, since you have them off get the heads pressure tested. They will have cracks as it is a Lanova chambered engine, but some cracks do not hurt you. Later. J.
