Re-powering 1650 oliver with 1800 engine
brent kubat
06-06-2007 20:34:59
I have a 1650 oliver diesel tractor with a bad waukasha engine, I already have an 1800 waukasha diesel engine that I am working on installing. My question is can I use a 1650 flywheel on the 1800 engine with no bad effects? I know it will bolt up, but the 1650 flywheel is smaller. I only use this tractor for light duty work such as bailing hay & pulling wagons. I appreciate any input on this. Thanks!
J Schwiebert
06-07-2007 15:10:15
 Re: Re-powering 1650 oliver with 1800 engine in reply to brent kubat, 06-06-2007 20:34:59
What series 1800 engine is this? A B or C? J/
Brent Kubat
06-07-2007 20:21:28
 Re: Re-powering 1650 oliver with 1800 engine in reply to J Schwiebert, 06-07-2007 15:10:15
It is a C model
Fred Whittaker
06-07-2007 09:26:12
One more thing to think about is heat. Will you be able to use the radiator from the 1800? If not, I would think that the 1650 radiator would have a thinner core, and maybe shorter. My uncle did something similar to what you are talking about doing. He put an engine from a 1950-T in a white 2-70. He ended up having to use the radiator from the 2-70. About all that he can use the tractor for is raking hay and moving round bales. Any larger load than that causes it to overheat. Granted the 1800 engine most likely produces less heat than a 1950-T engine would, but I'm sure more than the 1650 would.
Brent Kubat
06-07-2007 20:24:38
 Re: Re-powering 1650 oliver with 1800 engine in reply to Fred Whittaker, 06-07-2007 09:26:12
Yes I am going to use the 1800 radiator. Not much choise on this as the 1650 radiator is junk.
mcb
06-06-2007 20:43:54
THat should work just fine!! I put a 310 out of an 1850 in a 77 and used the 77 flywheel and used it only for pulling and that worked good!!
Ben Rauls
06-07-2007 16:49:12
 Re: Re-powering 1650 oliver with 1800 engine in reply to mcb, 06-06-2007 20:43:54
When you repowered your 77 how much custom work was there? I'm lookng to do something with my 88 diesel
Thnaks Ben
brent kubat
06-06-2007 20:52:45
Thanks MCB,I guess my main concern was so I will not do any harm to the engine by using the smaller flywheel.I know the 1650 clutch is a little smaller- 11 1/2" approx. compared to a 13" that the 1800 uses.
RAB
06-06-2007 23:11:14
 Re: Re-powering 1650 oliver with 1800 engine in reply to brent kubat, 06-06-2007 20:52:45
Keep in mind that "that little difference" in clutch size means the 1800 clutch is 28% bigger than the smaller one - that is close to a third! Will depend on friction area and clamping force among other things, but remember if you over-torque a clutch it will slip or break.
Regards, RAB
