oliver 66 fuel consumption
Rustin
06-04-2007 09:42:15
Doe anyone know what a oliver 66 (gas) would use for fuel on an hourly basis, gallons per hr. It would be under some load, but not heavy.
rrlund
06-06-2007 06:23:35
 Re: oliver 66 fuel consumption in reply to Rustin, 06-04-2007 09:42:15
Hi guys,funny you should talk about this. I ran my generator for two days straight a year ago February,it's 12000 kw,the 66 went through a tank of gas every 10 hours. I don't remember the capacity,16 gallons maybe,so 1.6 gal/hr.
J Schwiebert
06-04-2007 18:32:52
15 KW? Does't that work out to a thoretical 20 H. P.? Now is that always a constant load or does the load vary? Also is the 66 in good shape? Is it stock displacement or does it have larger sleeves and pistons been installed? At what RPM do you need to run the generator or is it PTO driven? Just asking? J.
Rustin
06-04-2007 19:51:28
 Re: oliver 66 fuel consumption in reply to J Schwiebert, 06-04-2007 18:32:52
whoops forgot to say. Load varies between 8kw and 15kw.
e
06-05-2007 10:36:55
 Re: oliver 66 fuel consumption in reply to Rustin, 06-04-2007 19:51:28
You'll be asking a lot of that 66 if you expect 15kw. 15 kw is 20 hp and if your generator is 90% efficient, you'll need at least 22 hp. A 66 is rated at 23 hp PTO. Might want to consider a bigger tractor.
Rustin
06-04-2007 19:50:11
I think it is stock displacement. I do know that it has had domed pistons when it was rebuilt about 20 years ago (300 hrs ago). The generator is PTO driven.
evielboweviel
06-04-2007 16:57:39
you won't run it empty doing regular work in a day. Now plowing it will suck down some fuel.
Ron
steveormary
06-04-2007 17:38:27
 Re: oliver 66 fuel consumption in reply to evielboweviel, 06-04-2007 16:57:39
Rustin,
2-3 gal/hr depending in load and which way the wind is blowing.
steveormary
Rustin
06-04-2007 17:30:38
Well its going to be working quite a bit, going to be spinning a 15kw load.
Don in Mich.
06-04-2007 20:33:33
 Re: oliver 66 fuel consumption in reply to Rustin, 06-04-2007 17:30:38
I don/t think a 66 has enough horses to produce 15 KW
Rustin
06-05-2007 15:49:26
 Re: oliver 66 fuel consumption in reply to Don in Mich., 06-04-2007 20:33:33
Yea i think i might end up getting out the jd 1530. Thx for help
