hydraulics problem on a 1650
Gary Hutchinson
06-04-2007 08:23:37
I am considering buying a 1650 with a loader which runs off the built-in hydraulics. The loader
works, but there is interaction between the two
ports such that when you lower the arms, the bucket tips forward also. I think (working from
memory) that the control that tips the bucket
may have been backwards from what you would expect. Could that account for the interaction
between the two controls or is there a problem with the internal valve like leaky o-rings?
B A Star
06-04-2007 12:11:40
 Re: hydraulics problem on a 1650 in reply to Gary Hutchinson, 06-04-2007 08:23:37
    Tell us more about how the loader is attached to the tractor hydraulic's.  Are the cylinders two way for both the bucket and the boom arms?  If either the bucket or boom cylinders are one way, tell us which ones or both.
  Then we should be able to tell how to trouble shoot & correct the problem.
Gary Hutchinson
06-05-2007 06:19:47
 Re: hydraulics problem on a 1650 in reply to B A Star, 06-04-2007 12:11:40
The cylinder for the bucket is double-acting and the cylinders for the arms are single-acting.
After taking another look, there are a front and rear port on either side of the tractor in the area of the 3-point lift arms. The two levers
for the hydraulics are mounted concentrically
on the same shaft on the right side with the one
inboard operating the bucket tilt and the outside
lever controlling the arms. The left side front
port connects to the bucket tilt down end of the
cylinder, the left rear to the bucket tilt up.
The right side front has a plug screwed into it
and the right side rear comes out, splits, and goes to the lift end of both arm cylinders. The
action on the control arms is: inside lever forward, bucket tilts up, backward, bucket tilts down. Outside lever forward, arms down, backward,
arms lift.
