Tranny Fluid Question for Super55
John in WI
01-03-2000 08:27:41
Hello. I've got a question regarding the tranny fluid in in 57 Super55. I was told from the previous owner(dealer) to run 80/90 gear lube in it. Does that sound right? I also may have a problem. I was working the tractor for about an hour doing some light loader work(loading horse manure into a spreader). The outside temp was about 35 degrees. When I put it away, I decided to check the tranny fluid level and removed the plug. A yellow foam came pouring out and continued for about an hour. After things settled down, I saw that the level was at the plug level. Why did it foam? I store it inside and the dealer said that he changed the fluid out prior to delivering to me(July 1999).
Anybody have some ideas as to what is causing the fluid to foam?
Thanks for responding.
John
Dennis(WA)
01-05-2000 08:10:41
 Re: Tranny Fluid Question for Super55 in reply to John in WI, 01-03-2000 08:27:41
Your fluid is foaming because it has water in it. If the dealer did change the fluid, he did not get out all of the water. You probably need to drain your tranny, pour in about 2-3 gallons of kerosene, run it for a few minutes, then drain it again. Then refill it with 85-140 wt gear oil, not 90 wt. The manual says 140 wt. all year round. Enjoy your Super tractor!
