White 2-135, 2-155
Moline_guy
06-02-2007 13:45:58
Need to know if drive train is the same on 2-135 and 2-155, and also if the any of the drive train parts from a 4-180 are interchangable with a 2-150, found a 4-180 cheap with blown engine and rotted tires just wondering which rear ends were used in this one. Also would like to know if parts interchange between a 135 and 155 two wheel drive, thanks for any replies.
Moline_guy
06-02-2007 21:18:50
 Re: White 2-135, 2-155 in reply to Moline_guy, 06-02-2007 13:45:58
Thanks for the replies we have a 2-155 but found there is a 135 coming up at an auction and was just wondering if parts could be swapt between the two, guess not. As far as the 4-180 goes i just assumed being it had planetaries it was the 2-150 rear end but now i am not sure, decided to stay away from it because it wouldn't be much use to the 4-150 or 2-150 we have anyway, i guess the guy is selling it to a salvage yard. Thanks for the input.
kkiowa
06-02-2007 20:06:32
The 4-150 used 2-105 rear ends. The 4-180 used the outboard planetaries rear ends same as the 2-150/2255 and a two speed drop box , the 4-150 used the over/under.
Dean Barker
06-02-2007 17:38:36
The 2-135 and the 2-155 are the same basic design, but there are differences. Starting from the back, the 2-155 had wider inboard planetaries. I believe that some of the transmission gears on the 2-155 were wider. I think that the over/under transmissions were the same. That is about it.
Sam in Mi
06-02-2007 20:49:39
 Re: White 2-135, 2-155 in reply to Dean Barker, 06-02-2007 17:38:36
Not sure about the earlier ones, but we had a series 3 2-135 that had an over/under with about 3.5 quart oil capacity. I believe the 2-155 had a heavier unit that was around a 6 quart oil capacity.
Sam
CumminsMan
06-02-2007 17:11:02
4-180 used 2-105 rearends
