Oliver 60 Standard Trans/Diff Fluid
Toolsmith
05-31-2007 14:00:09
I inherited an Oliver 60 Standard and am trying to get it in running condition. I have a reproduction manual, but I am confused by the changing of the trans/diff fluid.
The tractor appears to have a fluid level plug on the left side of the tractor below the foot pad sheetmetal. There is what appears to be a filler plug by the shifter as well as a slotted screw plug right below the shifter. I am going to assume that you fill through the plug by the shifter to the level hole on the rear housing? What is the slotted screw plug for?
Also there is another small level or drain plug and a filler plug on/near the PTO. Is this a separate system that needs to be drained/filled? If so does this take the same fluid as the trans/diff?
Sorry for my ignorance, but the manuals are very vague and I don't want to waste the lube at the price you have to pay for it.
Thanks
Ron Grother
06-01-2007 02:59:28
 Re: Oliver 60 Standard Trans/Diff Fluid in reply to Toolsmith, 05-31-2007 14:00:09
it should take about 6 gal. what is the matter with the old oil its a lot better then the new stuff. it will hang on the gears. the new oil wount.
Don in Mich.
05-31-2007 14:53:08
Fill at plug by shifter to the oil level plug at rear housing. pto is seperate, fill at plug by shifter till it comes out plug below the pto shaft, i use 80-90 gear oil.
