Super 55 Hydraulic oil
Banks Wallace
05-31-2007 05:23:42
My Super 55 is losing hydraulic oil into the gear oil. Can any one tell me where to start looking for the problem?
Matt Kane
05-31-2007 12:57:00
 Re: Super 55 Hydraulic oil in reply to Banks Wallace, 05-31-2007 05:23:42
There could be pinholes in the piece between the hydraulics and the transmission. The top will have to be removed to check it out. If its losing fast I wouldn"t run it until you get the leak fixed. If the pump gets damaged then you are talking some money. Also the center plate in the pump could be cracked.
RAB
05-31-2007 05:42:46
Between the hydraulic and the transmission housings, I would guess. Wouldn"t start anywhere else.
RAB
Larry from md
05-31-2007 11:03:00
 Re: Super 55 Hydraulic oil in reply to RAB, 05-31-2007 05:42:46
Pump seals.
