S55 voltage regulator
Chief 83
05-27-2007 06:38:00
I need to install a voltage regulator on my Super 55 Diesel. The pictures all show one attached to the generator. My gen has one small hole available. Is that all that is needed? I could also use a more remotely mounted regulator if necessary. I need a model or part number for the regulator and any suggestions on mounting location other than the gen would be great.
MikeS55d
05-29-2007 13:05:01
 Re: S55 voltage regulator in reply to Chief 83, 05-27-2007 06:38:00
It's an easy to find Delco (12v, pos grnd, 4 terminal) with a curved bracket to match the generator case. 2 screws hold it on, one is somewhat hidden back towards the head. Screws go into holes tapped in the generator case. Saw one at Tractor Supply yesterday, most tractor parts supply places will have it.
J Schwiebert
05-27-2007 09:58:49
Going by memory here but the last 3 Delco numbers were 791 for the 12 volt models. Is your problem with the cutout or the current/voltage unit. Is it gounded well?
Chief 83
05-27-2007 19:27:08
 Re: S55 voltage regulator in reply to J Schwiebert, 05-27-2007 09:58:49
J, I don't have one at all. When I got the tractor there was nothing left of the regulator. It was remotely mounted and obviously not the right one. So I'm starting pretty much from scratch.
Mike (WA)
05-27-2007 09:23:38
You could attach the stock variety on the generator with a large hose clamp going around the generator. Just be sure to run a separate ground wire to a good ground. Sorry, I don't have the part number off hand.
