Cockshutt 30 LPTO
Allan Lance
05-26-2007 20:04:16
hi there
I have a Cockshutt 30 with LPTO that is slipping under load, do I need to replace the entire assembly or can I just get in there and replace shims and tighten up the clutches? I don't know much about the intrcacies but would appreciate any help, thanks for now and I appreciate all the input
P Heisey-Harleysville,PA
05-28-2007 04:54:51
 Re: Cockshutt 30 LPTO in reply to Allan Lance, 05-26-2007 20:04:16
Allan,
The clutch pack when new with three Heavy Duty metallic clutch discs had five .010 shims under each of the three feet of the bracket & spacer assy. Remove some or all of the remaining ones still in there to tighten up and eliminate the ware tolerences. If there are none to be found, you will need to install a new clutch pack and install five shims under each foot.
Phil Heisey 215-256-8651 FAX 215-256-1203
krm
05-27-2007 20:17:45
If you need parts contact Irv Buttray at [email protected].
J Schwiebert
05-27-2007 09:56:48
Well it is an overcenter wet clutch and is shim adjusted. Take a couple (same thickness) out of each pac and see what that does to solve the problem. If it rains this afternoon i will see if i can find the specs. J.
