Oliver Standard vs RC gear ratio
Dan in Ore
05-26-2007 18:55:19
A friend of mine let me drive his 1948 60 Standard today. I noticed that the gear ratio seemed a lot higher than my 88 RC.
Did the standard have a higher rear axle gear ratio than the RC?
Reply
05-27-2007 20:42:00
 Re: Oliver Standard vs RC gear ratio in reply to Dan in Ore, 05-26-2007 18:55:19
My brother had a 77 standard. It was geared higher than the row crop 77's. 1st gear in the standard felt like 3rd gear in row crop.
RAB
05-27-2007 00:46:33
Dan, not sure that a 60 is particularly comparable with an 88. Gearbox ratios are probably different for a start, axle ratios for another and wheel sizes for yet another. Probably you need to know which gear set is fitted if there were choices.
RAB
