Oliver 2255 hydraulic leak
kodger
05-23-2007 03:34:29
Just noticed my 2255 was leaking hydraulic fluid from the drain hole (?) at the bottom of the left brake cover. Probably not going to attempt to fix for a while. Any ideas on what is wrong or how hard of a fix? Thanks in advance.
m kuhns
05-23-2007 09:50:40
 Re: Oliver 2255 hydraulic leak in reply to kodger, 05-23-2007 03:34:29
Probably the seal for the brake piston is leaking. It will only get worse. They make seal kits for the pistons, just two O/R's. All you have to do is remove the outer cover which contains the piston and reseal it. I would check your 3 brake discs while your in there.
