Oliver 80's total weight
Margit
05-21-2007 19:19:45
Hello, Does anyone knows what is the total weight of a 1946 Oliver 80 row crop?
Thank you
chparks
05-23-2007 12:00:09
 Re: Oliver 80's total weight in reply to Margit, 05-21-2007 19:19:45
The book I used was the Oliver Data Book by Brian Rukes. I also have a 1947 Tractor Field Book. I beleave those wights are more reallistic.
I should have looked farther.
Ken L.
05-22-2007 16:08:01
I have an 80 row crop on rubber 11X40 rears loaded with cast centers. It weights well over 6000lbs.
chparks
05-22-2007 13:36:37
The Data Book by Rukes said 3300 lb approx. on
rubber.
oliver fan
05-22-2007 15:46:29
 Re: Oliver 80's total weight in reply to chparks, 05-22-2007 13:36:37
chparks, i am not familiar with the data book you are referring to, but I though the 3300 lbs. that you quoted was a little light, so I looked up the orginal advertising for the 70 row crop and the 80 row crop.
The 70 row crop weighs 3200 lbs. on steel and 3400 lbs. on rubber. The 80 row crop weighs 4545 lbs. on steel according to Oliver advertising brochures. This is shipping weight.
I then looked in the 1947 Tractor Field Book and they list the 70 row crop as 3200 lbs. on steel and 3300 lbs. on rubber. In the same book thay list the 80 row crop as weighing 4600 lbs. on steel and 4775 lbs. on rubber. This is also shipping weight.
Maybee there is a misprint in the book you quoted, or maybee my references are wrong.
