White construction identification
rufusjd
05-21-2007 10:29:37
Hi, I reciently purchased a White model number 515-71044, serial number 222 890-484 tractor with a front loader and back hoe attachment. On the ID tag where I found this information it says White Construction Equipment a division of White Motor Corp. Northfield Illinois U.S.A. Can some one tell me what year this machine was made and what it is called. It has a 4 speed transmission with a forward and reverse shuttle. I don't know for sure but the tractor looks like a Oliver 550. The hoe looks like a Oliver 613 and from what I can tell the front loader appears to be a 578. I'm assuming this machine came from the factory with both the front loader and back hoe attached to what appears to be an Oliver 550 tractor. The paint underneath the brighter yellow repaint appears to be a more of a cream colored yellow that is not so bright which may be how it came from the factory. I saw a add for an Oliver/White 2-44 for sale which looks like mine but it had a 6 speed transmission not a 4 speed like mine. I would like to know exactly what mine is called, year made model etc. Thanks in advance.
oliver fan
05-21-2007 17:54:35
 Re: White construction identification in reply to rufusjd, 05-21-2007 10:29:37
Your tractor/loader/backhoe is a White 2-44L built in 1970. The L letter tells you it is a 578 loader. On the upper part of the backhoe near where you sit should be the Decals. There should be one on each side and should say 2-44 and right under that number it should say either 13 OR 13L. Can you scrape some of the newer paint off so you can read the decal? Some of these models had the 6 forward 2 reverse as standard equipment, and some had the optional 4 foward 4 reverse like yours.
I have one that is simular to yours, except mine is a White-Oliver built in 1967. Mine is a 2-44LL. Mine has the 588 loader and that is why it has the double L's. I also have the 4 foward 4 reverse transmission.
In other words if it has the 578 loader it will be a 2-44L and if it has the 588 loader it will be a 2-44LL. The 13 on the backhoe on both of ours is the backhoe model number, and also means the digging depth of the hoe.
rufusjd
05-22-2007 07:11:08
 additional 2-44 questions in reply to oliver fan, 05-21-2007 17:54:35
OLIVER FAN, Thanks so much for your prompt reply and for your help. I have many more questions like how to identify a 578 verses a 588 loader. I got a 610, 613, 615 back hoe manual with the machine and I used the total length chart to decide that mine was a 578 but I'm not sure. Also I'm having trouble finding 3rd and 4th gear, how exactly does the shifter work. Is it straight line or a "H" pattern. Can I use regular heavy equipment hydraulic oil or do I have to use engine oil with an additive as specified in a 1973 Oliver 550 operators manual that came with my 1970 White 2-44? . What is the paint code for a 1970 WHITE 2-44. It would be nice to talk to you directly via phone or email, is that possible? Since you have a 1967 2-44 you probably can answer all my questions. Hats off to everyone involved in this discussion board, it's an invaluable source of information for a new owner like myself.
oliver fan
05-22-2007 15:54:56
 Re: additional 2-44 questions in reply to rufusjd, 05-22-2007 07:11:08
I sent you a E-Mail. If you don't get it, post back here.
oliver fan
05-23-2007 21:04:36
 Re: additional 2-44 questions in reply to oliver fan, 05-22-2007 15:54:56
Rufusjd,
Your 2-44 with loader and backhoe weighs at least 8000 lbs. Also, Korves Oliver's telephone number is 618-939-6681. They will have most, if not all the parts you need.
Good to talk to you. Oliver Fan
