1941 Oliver model 60 tractor
Scott Green
01-01-2000 09:37:08
I had just bought a Oliver "60" tractor which had sat out in the rain and snow for approx: 6 months.I may need to replace a couple of cylinders in the engine.This is my first Oliver 4 cylinder engine.I don't know much about them.Here is my question. Is the Oliver/Waukesha engine in the model "60" the same as the ones in the model "66" , super "66" , and "660"? Are the parts interchangable? If not , where would be a good place to start looking for parts? Scott
Bill Lane
01-15-2004 19:02:24
 Re: 1941 Oliver model 60 tractor in reply to Scott Green, 01-01-2000 09:37:08
Scott,
The engines are not the same. Check with the Tractor Supply Company for engine parts. Also a tactor junk yard in Willard, Ohio and the Andrew Goodman used tractor parts place in Lincoln NE.
I sold mine in 1990 to a man in Tennesse.
All the engine parts are replacable with the exception of the valve seats.
Your obedient servant,
Bill
chris
01-01-2000 18:37:57
Call 1800 808 9934 in ohio. This is where I got all the overhaul parts for my 41 60.
Jerry B
01-01-2000 10:38:40
The 60 engine is not the same as the 66, ect.
If you can find a running 66 or S66 engine you can just install it into your 60 and have a lot more power at less cost than it would take to rebuild your present engine.
Wish i had done that rather than set about rebuilding my 60 engine.
roger
01-01-2000 17:54:21
 Re: Re: 1941 Oliver model 60 tractor in reply to Jerry B, 01-01-2000 10:38:40
The oliver 60 and 66 are not the same. I have a 60 and a 66. The 66 engine is longer than the 60. You would have to make motor mounts for it, among other things.
Scott
01-10-2000 21:54:12
 Re: Re: Re: 1941 Oliver model 60 tractor in reply to roger, 01-01-2000 17:54:21
I just wanted to thank you all for the information you had given me.It's nice to have a place like this to ask questions and opinions of people with tractor experience.
