1937 Oliver/Hart-Parr 28-44....High Compression or
Andrew Walker
05-16-2007 19:31:11
I have a 28-44 whose serial number makes it a 1937. What is obviously,physically different about the high-compression models to help one determine if, indeed, it is an HC model ? Is the gas tank different ? Did they stamp the tag as 32-50 or with an HC ?? Is there a certain part number on the head ? Maybe a different carb ?? I'm aware that Oliver put a high compression head on these models but is that it and how do you tell without pulling the engine apart ?? Thanks in advance.
Andrew Walker
05-20-2007 17:21:23
 Re: 1937 Oliver/Hart-Parr 28-44....High Compressio in reply to Andrew Walker, 05-16-2007 19:31:11
Thanks much guys ! I only knew about the different head so the rest of the info is refreshing. Looks like mine isn't one of the HC models as it certainly isn't a 4-speed. Thanks again.
Jim Kline
05-17-2007 09:36:00
All High Compression Specials have AC33 stamped behind the serial number. They all have starters, 4-speed transmissions, high compression heads, have large OLIVER with small Hart-Parr on the radiator top, Hart-Parr cast into the left side of the block, fixed speed governors. Not to be confused with the Oliver Thresherman's Special.
Lee W
05-17-2007 06:23:42
The part no's are stamped under the valve cover, there were three different heads avaiable for that series of motors. The A180A is Kerosene the E head is gas and the D head is high altitude. The E head has the round plugs on the manifold side with the square holes in them. I think all of the high compression models were four speeds.
