Carb Linkage 1550 ??/
SJ
05-16-2007 05:35:46
The little clamp that holds throttle cable separated from carb linkage. Can this be replaced or repaired? I cant tell if it broke or what? Does it snap into the linkage hole,or attatch some other way. As of now it wont stay in the hole.
Thanks stan
rrlund
05-16-2007 06:40:07
 Re: Carb Linkage 1550 ??/ in reply to SJ, 05-16-2007 05:35:46
I'm not quite clear what you're talking about? The choke uses a cable. The throttle linkage is a rod. It just has a cotter pin through it to hold it to the lever on the carb.
SJ
05-16-2007 12:16:03
 Re: Carb Linkage 1550 ??/ in reply to rrlund, 05-16-2007 06:40:07
Doh,,your right it is the choke cable.
thanks Stan
