SORRY, I LEFT OUT THE TRACTOR TYPE
David Lee Hawki
05-15-2007 18:00:17
The tractor is an 1960 Oliver 550
Tpost
05-17-2007 06:19:09
 Re: SORRY, I LEFT OUT THE TRACTOR TYPE in reply to David Lee Hawkins, 05-15-2007 18:00:17
Still sounds like an adjustment problem to me being as you can engage it by hand with the cover off. Some times it just takes time trial and error. I had a 1650 a couple years ago I thought I would never get right. If you adjusted it to keep the PTO from spinning while disengaged you may never get bowth. Dont worry too much if it spins a little while disengaged it usually will have no torque so long as it IS disenguaged. Check some of the past posts on this your not the first with a 550 and a pto problem. Good luck.
