Oliver Super 55 Water Pump Rebuild
Anonym
05-15-2007 06:18:48
I believe I blew my water pump over the weekend in my 1955 Super 55. I was working up my backyard for sowing grass when I started to hear a clanging coming from under the hood. When I looked, the fan was wobbling and a blade would hit the shroud at higher rpms and there was a nice stream of coolant running down the front of the block. Is this the typical signs of a bushing/bearing going out in the pump?
If so, where would be a good/cheap source for a rebuild kit? Will all S55/550 kits work on this tractor, or were there design changes along the way? Also, is there anything I should do to verify that a rebuild is what I need instead of a whole new pump?
Thanks in advance.
Justin in Indiana
Anonym
05-16-2007 07:05:25
 Re: Oliver Super 55 Water Pump Rebuild in reply to Texas Oliver Connection, 05-15-2007 18:25:46
Kent,
Thanks for the reply and information. Hopefully I'll get her lined out soon!
Thanks,
Justin
