Carb settings/oliver 60
wayne robinson
05-14-2007 19:16:47
Got my 10yrs dormant Oliver 60 to start & run today!!For about 30 seconds then she died from fuel starvation Got her to fire about 4 more times by spraying fuel in the mouth of the rebuilt carb,Don't know where the shop set the screws or which screw is which,Any one with a count or explanation of what screw is what would be appreciated
Ken L.
05-15-2007 16:01:15
 Re: Carb settings/oliver 60 in reply to wayne robinson, 05-14-2007 19:16:47
I usually start with both set at about 11/2 turns from all the way in and adjust from there once it's running. You may need to remove the carb and clean or rebiuld it. Setting that long, it could be gummed up.
wayne robinson
05-15-2007 19:09:23
 Re: Carb settings/oliver 60 in reply to Ken L., 05-15-2007 16:01:15
Oh yes it was gummed up Tank a mess too but all system are restored to original quality,yet "Me thin' some tings wrong wid the screw" mon, after firing & running she starves out yet i have a supply at inlet port of bowl(pulled the hose of & seen it flowing)I will try your suggestion to see if that improves it, gracios!
