Super 55 Hydraulic Pump
Matt Kane
05-13-2007 14:33:08
My hydraulics on my super 55 were weak, so I decided to pull the cover from the tractor. When I inspected the pump. There was a little slop on the gear part of the pump, and the slots in the rotor were slightly curved. Should the slots in the rotor be just large enough for the vanes? I was getting some air in the fluids, and once the tractor warmed up the lift was weak. Haven"t gone too far into it yet.
J Schwiebert
05-13-2007 16:49:23
 Re: Super 55 Hydraulic Pump in reply to Matt Kane, 05-13-2007 14:33:08
Make the press test!. J.
Matt Kane
05-13-2007 15:21:53
Think I found the problem. The leather washer was almost gone and the o-ring on the piston was flat. All my fluid was going around the piston. I think the pump is okay and the castings look nice. Anything I should do while I am in there? Don't feel like removing that cover by myself again.
Super 55
05-13-2007 16:55:50
 Re: Super 55 Hydraulic Pump in reply to Matt Kane, 05-13-2007 15:21:53
It's a tad heavy isn't it. Like John says do a press test. If you don't have the manual email me and I will scan it. [email protected]
Matt Kane
05-13-2007 17:33:55
 Re: Super 55 Hydraulic Pump in reply to Super 55, 05-13-2007 16:55:50
Tad, yup. I weigh about 135 and managed to get it off by myself. I will get help to put it back on. I have noticed some gear wear, but thats something I won't mess with. I just want strong hydraulics. I think maybe at one time someone had the hydraulics worked on.
