Over Under Fluid?
NEB from MO
05-11-2007 13:59:49
What kind of fluid am I suppose to use in my 1855's Over Under?
Dean Barker
05-12-2007 23:08:17
 Re: Over Under Fluid? in reply to NEB from MO, 05-11-2007 13:59:49
Use AGCO's universal hydraulic fluid in both the over/under and the hydra-power. Also, use the better filters, either 30-3475433 (long) or 30-3475425 (short). AGCO has recently reduced the price of these better filters; the price is not as out of line as it was a year ago.
CLIFF CAREY
05-11-2007 21:12:41
Use AMSOIL Trans Fluid.
bradk
05-11-2007 19:41:17
When I bought a rebuilt 3-speed from O'Brien Co. implement,It came pre-filled with universal hydraulic fluid.Tom at the dealership says that's what should be in it.Better lubricating properties and works better under pressure.
All later Olivers came with universal (or equiv) and not ATF.White kept on with this.
When servicing our hydra-power drives,We use universal in them also.
~brad
Tom Ia
05-11-2007 17:26:17
I use ATF.
oliver-2150
05-11-2007 14:10:46
ATF is not the correct fluid for a 3 speed. it works ok in a 2 speed , but there is a special fluid for it. i think my jug is from agco. if you need i can go to the barn and see exactly what it is.
Wisconsin Cowman
05-11-2007 14:02:44
I use ATF.
Wisconsin Cowman
05-11-2007 14:02:44
I use ATF.
