Is this normal, afterall?
newter haven
05-10-2007 19:16:18
The 110 is back together again. Checked the crank, put new rod and main bearings in and also thrust bearings, new clutch and throw out bearing, waterpump, belts, filters, all hoses too. Went one more step and replaced front cab mounts. My question is is it normal to here the clutch disengaging and engaging inside the cab? That's the reason we dug into it to correct this noise. I've come to the conclusion that I'll just have to live with it and turn up the radio! If anyone has a late model 105 or 110 is this what you hear, too? Thanks for reading.
