Fleeline series tubs
bannered in bos
05-10-2007 13:36:40
Are the tubs from a 66 and a 77 interchangeable?
eddyjoe
05-11-2007 17:44:08
 Re: Fleeline series tubs in reply to bannered in boston, 05-10-2007 13:36:40
Anything is interchangable given enough time and money, but those will not be a bolt-up project. Transmission to tub joint is different widths on the 77 and 66. And yes, the mounts inside are different. But the 66 or 77 did not use a chain coupler. It has a splined coupler to marry the clutch output and the trans input.
cmccoy
05-11-2007 05:26:26
I have two 88 tubs which should be the same as a 77. I live in Indiana. Let me know if interested. I will sell cheap. Chris
bannered in boston
05-12-2007 07:14:27
 Re: Fleeline series tubs in reply to cmccoy, 05-11-2007 05:26:26
Actually I was looking for a tub that would fit a 66. I have a 77 tub and I too will sell it cheap, very very cheap.
J Schwiebert
05-10-2007 17:48:32
Well the 66 is a 4 cylinder, the 77 a 6 cylinder so the motor mounts are indifferent locations to start with.
bannered in boston
05-10-2007 21:44:18
 Re: Fleeline series tubs in reply to J Schwiebert, 05-10-2007 17:48:32
Are the motor mounts a part of the tub?
Don-Wi
05-10-2007 22:32:11
 Re: Fleeline series tubs in reply to bannered in boston, 05-10-2007 21:44:18
Yep. The motor mounts to the tub, which mounts to the rear end, and power is transfered through a chain coupler.
