Oliver 1850 Diesel W/F Row Crop 2WD
olrusty
05-08-2007 18:17:45
I have an Oliver 1850 Diesel wide front for sale. I bought this tractor as a project tractor but I can never find time to finish it. There are many new parts that I have bought for this tractor in trying to get it up and running. The previous owner had the head blow between #1 & 2 Pistons that was my starting point. I bought a different head and had new valve guides with reseated valves. The block was professionally reworked by a high performance engine shop (I have dealt with them on many engine projects both tractor and truck engine with no troubles after-words this shop knows their engines). I have a brand new exhaust manifold for the engine. I was told the engine preformed great up until the head let loose. The whole front end was rebuild spindles, NEW tires & tubes, NEW front rims, NEW tie rods. This tractor has 20.4 -38 rear tires yes they are tall with about 60% tread. Ones loaded the other is not. Those rims are in good condition. It has the three point arms, all the sheet metal (in good condition). The seat was shot but the frame is good. There are NO weights that go with this tractor. As long as I have owned this tractor it has been stored inside. This tractor needs an engine rebuild kit to get in back up and running. I am not going to part this tractor out because I feel that this is a good tractor for someone that will put some time into it to make it a great tractor. I am selling this AS IS you come pick it up. I am asking $3,000 OBO. I can supply pictures if anyone is interested please let me know I can help load.
rr570
06-27-2007 19:38:41
 Re: Oliver 1850 Diesel W/F Row Crop 2WD in reply to olrusty, 05-08-2007 18:17:45
which engine does it have perkins or wakesha, would u consider selling without the new tires, i dont need them
MikeOwi
05-08-2007 21:13:27
Pictures would be good and I need to know where you are located. When the engine was reworked, it was done to specs, not souped up I would presume. Thanks
olrusty
05-09-2007 09:39:43
 Re: Oliver 1850 Diesel W/F Row Crop 2WD in reply to MikeOwi, 05-08-2007 21:13:27
This is the link to the photo ad that I placed. I will e-mail other pictures Soon!
Thanks Brian A.
http://www.tractorshed.com/cgi-bin/photoads/classifieds.cgi?search_and_display_db_button=on&db_id=172510&query=retrieval
zimmy10
05-08-2007 21:10:58
could i see some pictures please... what new engine parts??
dwm7
05-08-2007 20:29:20
Over/Under or Hydra Power? Serial or Year? Where is it?
olrusty
05-09-2007 09:43:13
 Re: Oliver 1850 Diesel W/F Row Crop 2WD in reply to dwm7, 05-08-2007 20:29:20
The tractor is a 1967 it has the Hydra power drive. Which i was told work. It is located in Michigan 49431. Mid west coast. I will get the serial Numbers Soon!
