Oliver Super 99 Diesel
Dave
09-01-1998 15:08:13
Could anybody please tell me the engine size (bore & stroke) and horsepower. I thought the engine might be a 2 stroke with a blower because of the JD 435 which has a GM 2-51 2-stroke with a blower. Does the hydraulics have a common sump with the rear axle or does it use a separate system? Thanks for any help you can give. Dave
Frank
09-09-1998 19:42:31
 Re: Oliver Super 99 Diesel in reply to Dave, 09-01-1998 15:08:13
: Could anybody please tell me the engine size (bore & stroke) and horsepower. I thought the engine might be a 2 stroke with a blower because of the JD 435 which has a GM 2-51 2-stroke with a blower. Does the hydraulics have a common sump with the rear axle or does it use a separate system? Thanks for any help you can give.
: Dave
The Super 99 GM is 213 ci...71 cubic inches/cyl.
Super 99 was also available with 6 cyl. engine.
Mine has engine driven hyd.pump with separate
reservoir.
Kevin Coers
09-03-1998 19:26:22
According to a reference book that I have the bore and stroke of the 3-71 GMC diesel is 4.25 X 5.0 . The hp was rated at 77 drawbar and 83 belt hp. The cubic inch size is 231
Dave
09-04-1998 14:29:14
 Re: Re: Oliver Super 99 Diesel in reply to Kevin Coers, 09-03-1998 19:26:22
Thanks for the info. Dave
