Oliver 80 water pump.
Ken L.
05-06-2007 13:57:10
Has anybody removed the oil tube to the water pump and replaced it with a grease fitting? With the pump being lubed with engine oil, the front of the engine gets covered with oil. My 18-28 has a grease fitting and it seems to work. Just wondering if there is any difference in the pumps and if this will work.
RAB
05-06-2007 14:40:49
 Re: Oliver 80 water pump. in reply to Ken L., 05-06-2007 13:57:10
That bearing is a porous bronze bushing through which the oil seeps. Your 18-28 probaly has a greasy packing gland. Mine (those with those later pumps) are all like that - at least you know it is getting lubed. I doubt that a grease fitting will do more than accelerate any wear that has already taken place, by blocking the pores in the bearing. I have replaced those oilite bearings but there is still some oil loss.
Regards, RAB
Ken L.
05-07-2007 16:13:29
 Re: Oliver 80 water pump. in reply to RAB, 05-06-2007 14:40:49
Thanks, I guess I'll leave it alone
