Setting up an Oliver model 64 drill
GregC
05-03-2007 14:22:00
I'm going to plant a new pasture and wanted to use my model 64 drill. The previous owner thought he might have a manual but can't find it, I should have just ordered one earlier.
It has the grass boxes, not sure if all of them did or just some. The drop tubes from the main box are in pretty good shape, but the ones from the grass boxes are gone. Will flexible plastic tube be okay to use there?
I'm planting an orchard, timothy, brome and aliske clover blend with oats for cover. What seed should I put in which box? I was figuring on putting the seeds together depending on size and seeding rate.
larry h
05-03-2007 15:27:11
 Re: Setting up an Oliver model 64 drill in reply to GregC, 05-03-2007 14:22:00
all small seeds go in grain box og-clover etc all large go in back ie oat -wheat soybeans etc i can get a copy of a chart but the museum in charles city has the manuals
GregC
05-03-2007 17:54:25
 Re: Setting up an Oliver model 64 drill in reply to larry h , 05-03-2007 15:27:11
So the oats and larger seeds go in the small boxes on the back? I was totally backwards on that. The seed chart is still legible on the inside of the lid, I can use that for my settings.
One more thing I thought of, on the grain box there are small plates that cover half of the hole the seed goes down(if I'd gotten that manual I'd know what that was called) do those plates need to be in place or should they be removed?
I'll be ordering the manual ASAP, thanks for your help.
Centerplate
05-04-2007 04:13:52
 Re: Setting up an Oliver model 64 drill in reply to GregC, 05-03-2007 17:54:25
On the 64 the small seeds like timothy, alfalfa, clover etc go in the small box in the back. Brome goes in with the oats in the large or front box. The covers for half the holes in the large box are for high rate/low rate. I think left side is low if I remember correctly.
larry h
05-04-2007 16:06:27
 Re: Setting up an Oliver model 64 drill in reply to Centerplate, 05-04-2007 04:13:52
the small box is for the small seds some of them were on the front the plates regulate the flow rate
