Oil
Jim Meade
05-01-2007 12:58:49
I'll be draining the transmission and rear end oil. I'm considering putting in a good grade of transmission/hydraulic oil instead of the 80-90 multi purpose gear lube. Comments?
I'm also thinking of running Rotella T 15W40 synthetic oil in the 310D. Comments?
I'm running good hydraulic oil in the over/under. Comments?
Jim Meade
05-02-2007 15:04:16
 Oil and orifice size in reply to Jim Meade, 05-01-2007 12:58:49
Tom at O'Brien County Implement said that an important factor is the size of the orifices in the oil channels. My tractor was designed for 80-90 oil and he would not recommend moving away from it.
FWIW
newter haven
05-02-2007 21:47:34
 Re: Oil and orifice size in reply to Jim Meade, 05-02-2007 15:04:16
We've run 15/40 for a number of years in all of our vehicles, lawn mowers to over road trucks. Just hard to beat. Have to agree with Tom, though, certain compartments need different lubrication according to manufactures specs. Good luck!
Don-Wi
05-01-2007 23:48:05
 Re: Oil in reply to Jim Meade, 05-01-2007 12:58:49
third party image
I would for sure stick with 80-90 in the rear end. Hydraulic wouldn't be thick enbough to really "stick" to the gears when they're meshing, it would increase noise and wear in the drive train.
As far as running synthetic in the engine, It may help, but you're still gonna have to chaneg the oil more often than most tracotrs because of the small oil pan, unless you have a fab shop add about 3" to the pan. I think that will add another 1 1/2 gallons or so to the capacity, which will almost double it's current capacity.
I change the oil in our 1855 about every 50 hours. It' does all of the really heavy work so it burns oil and has extra deposits in it from that and the extra heat load placed on it. I know some guys change it at 100 hours, some at 50, and some of both crowds run synthetic in the engine and swear it adds 100,000 hours to the life of the engine.
For me, more frequent oil changes with a good 15W-40 deisel rated oil is good enough. For the price of synthetic you better have some deep pockets, espescially if it burns any.
Donovan from Wisconsin
Dean Barker
05-01-2007 21:11:35
I would stay with the 80W-90 in the rear end and tramsmission. The rest of your plans sound good.
Be sure to use the type 55 hydraulic oil as it is thinner than regular universal-hydraulic oil.
I've always wondered if John Deere low-vis hydraulic oil would be thin enough.
Stu
05-01-2007 14:18:25
I had an 1855 that had a new rotating assembly but since it didn't have oil cooler the pressure would drop as the temperature went up. I ran Mobile 1 synthetic 20w50 mixed with Lucas oil treatment in the summer & it gained 10-15psi at operating temp. Stu.
old
05-01-2007 14:13:40
What tractor?? Not all of them use the same stuff so not knowing the tractor you have its hard to help you
Jim Meade
05-01-2007 19:20:01
 Re: Oil in reply to old, 05-01-2007 14:13:40
1855D built in 1975
