Engine vibration
Joho
04-23-2007 05:07:42
I have a Super 88 that has a K100c engine in it. Compression on all cylinders is 145 cold cranking. Engine starts and runs fine but when the throttle lever is advanced to just about where the split in the notched plate is, I get a vibration. It does this whether the clutch is in or out. The clutch shaft,coupler and transmission input shafts are running true. Any ideas?
El Toro
04-23-2007 10:26:01
 Re: Engine vibration in reply to Joho, 04-23-2007 05:07:42
You may need to check the damper pulley to see if it is loose or the flywheel.
