Super 55 Locked Up
Norman Parker
04-21-2007 07:00:17
I have a Super 55 that had been stored for about 3 years. I got it running and was driving it in first gear when it locked up. The tractor will not move even if the clutch is in. The engine cannot be turned over. The pto clutch is not ingaged. I have tried everything and I cannot move this tractor. Help Me
J Schwiebert
04-21-2007 09:28:34
 Re: Super 55 Locked Up in reply to Norman Parker, 04-21-2007 07:00:17
You may need to take the shifter out and see if the 3 slots for all 3 shift rails line up. If not move the one that does not line up to where it does. Then see if it moves, if not push down on the clutch petal, hold it down and see if the transmission is free or if the engine turns over. Start there. J.
El Toro
04-21-2007 08:32:38
Can you move the shifter to neutral? Hal
