55 hydraulic problem
Steve - Kalamaz
04-20-2007 08:48:52
Rebuilt entire hyd system on 55. Lifts 2 bottom plow great when starting out. After 1 round will barly lift out of ground. Let it sit overnight and same thing happens. Fluid clean to start but when it won't pick up there is about 1.5 inches if white foam in reservoir but fluid is still cool. Any ideas?
Steve - Kalamazoo
04-22-2007 18:54:56
 Re: 55 hydraulic problem in reply to Steve - Kalamazoo, 04-20-2007 08:48:52
Filter is on side. How do I do pressure test.
Steve - Kalamazoo
04-20-2007 19:09:58
SN 16048-518 (1955) Replaced transmission cover w/late model one with larger reservoir, took everything apart (pump, valves, cylinder, etc.) and replaced all seals and o-rings.
J Schwiebert
04-21-2007 05:33:21
 Re: 55 hydraulic problem in reply to Steve - Kalamazoo, 04-20-2007 19:09:58
Late model as in filter on the side or as in filter in front? Did you do the press test when you had the unit apart?
J Schwiebert
04-20-2007 13:29:00
First of all do you have a serial number? What asll do you mean by rebuild it? Did you do the press test? Your getting air and that will caviatate the pump and will kill the pump. Also aearation will kill the pump so out of the 4 major killers you are dealing with two of them. Your turn. J.
