Neighbor bought an Oliver 1250
Dale in WV
04-16-2007 08:51:52
My neighbor bought a used Oliver 1250 24V diesel about two weeks ago. Parked it in the garage, waiting for the manual to arrive - and is still waiting... Anyway, he tried starting it Friday and got nothing but the click. Two 12V batteries there -- is it a weak battery or the starter? Is there some kind of safety interlock we"re missing, like clutch must be fully depressed before starting??? Not at all like my HF TO-30..
Bob Farrell
04-16-2007 12:40:17
 Re: Neighbor bought an Oliver 1250 in reply to Dale in WV, 04-16-2007 08:51:52
If you are getting a click I would think you are already beyond any safety switch(s) with the juice. Sounds like low batteries/bad connections on cables.
J. Schwiebert
04-16-2007 11:28:10
First of all you have a bad connection (s) and or bad battery(s). Get a volt meter or take of all the connections, clean them good make sure the batteries are fully charged. Once you get it to turn over it has glow plugs so will need to cycle them. More questions, if nooe else chips in wait till I get home ina couple of days. The diesl is a nice little tractor. J.
EasyG
04-16-2007 11:09:49
If it is like my 1265 then there is a saftey, I don't think about it, just do it, but I think that it has to be in neutral to allow it to start. Hope this helps
Dale in WV
04-17-2007 04:31:05
 He thinks it may be the Starter? in reply to EasyG, 04-16-2007 11:09:49
Neighbor feels he has adequate voltage at the starter -- so he's having that checked today. The transmission was already in neutral when he tried starting -- just got the click...
nailgunmt
04-18-2007 14:34:25
 Re: He thinks it may be the Starter? in reply to Dale in WV, 04-17-2007 04:31:05
I had an old 4020 that was 24 volt delta..one battery neg ground, one batt pos ground (knocked me on my a$$ more time that I want to count) make sure its straight 24 volt or you will chase it forever
