Oliver 1755 hyd probelm
Turner
04-15-2007 13:58:30
working a 1755 that has sat for 7 years tractor at a idle has low pressure on test gauge (1500 psi)above idle no pressure.Replaced compensator spring and seat new o-ring in relief valve seat changed unloader valve have bled system for air but not brakes .Still jerky steering at idle and jumpy 3 point and nothing at high idle . Hyd pump is warm but not hot to the touch.Using unico 75 fluid as oil.
