super 55 steering help
russell1
04-14-2007 18:01:44
I have just bought a super 55 that won"t steer left. When you try the steering wheel comes up out of the housing. Is this a fairly common thing and if so how is it fixed? Thanks for the help.
Chief 83
04-15-2007 20:24:30
 Re: super 55 steering help in reply to russell1, 04-14-2007 18:01:44
I just did mine. The earlier posts are correct. The bearings and race probably need replacement. Mine were totally shot. However my ball sector was fine. Korves Oliver has the parts you will need. It is a pretty big job time wise but not that hard to do once your in there.
MikeS55d
04-15-2007 16:51:36
It's pretty typical for Super 55 and 550 Olivers to need a steering box rebuild. As other posters said, water gets into the box and destroys the bearings. Do not try to force the steering wheel if it seems locked, that it when the ball bearings are jammed in the gears. Many Ford 8n bearings and seals will fit so they are not hard to find.
Click on "parts & pieces" in the column to the left, choose "oliver" in the box and then look through a few pages to find photos of a box disassembled. It is not difficult to rebuild.
Mike (WA)
04-15-2007 09:08:39
Typically, the lower bearing race ends up sitting in the water that leaked down the steering column over time, and it disintegrates, letting the bearing balls drift around til one jams the sector shaft on one side or the other, resulting in the worm just unscrewing instead of moving the sector gear. Get a manual (IT is fine), disassemble steering box, and repair.
rrlund
04-14-2007 18:36:59
I don't have the parts book right here in front of me,but I would imagine there is a taper bearing that has gone bad on the shaft,letting the gears push the shaft out.
