model 1600
to-nut
04-09-2007 15:46:48
i was wondering if they made a 1600 in a smaller version. i have a picture from around 1961 with 7 tractors side by side. this oliver in the picture is about the same size as a case 530 would that sound right to you guys.
Max Edlin
04-11-2007 16:53:32
 Re: model 1600 in reply to to-nut, 04-09-2007 15:46:48
Oliver did make a 1600 Utility. I have one. It has 18.4 X 26 rear tires, and the front axle is slightly different from a regular wide front. The axle is welded on to the spindle holder about 6 inches lower than the regular wide front. From the ground to the top of the cast iron grill is barely 5 feet. The fender brackets have two sets of holes to bolt the fenders to. On the utility the fender bolts in the bottom holes, on row crop models they used the top holes. The gear ratio is different for the utility, it will run in excess of 20 mph in high gear. If you want to see one I am planning to bring it to the Oliver Heritage show in Illinois this summer, come and look at it.
terry a
04-11-2007 05:19:58
The 1600 came out in 1962, I have an early example. It was also available in a utility model, which seems to be fairly rare, at least in our area. I don"t mean the row crop tractor with the underslung utility front end, those are fairly common. The utility version had much smaller tires and would look much smaller when next to a row crop tractor. There are a couple of these in our area, and are a really neat tractor.
to-nut
04-10-2007 13:50:14
i have a picture from around that time my dad swears it's 1961 or 62, but in the picture theres 7 tractors from around the neighborhood. my grandpa broke his back falling off silo and all of them came and help plow the feilds. there's two farmall m one h one 530 case one 450 farmall and one ferguson 35 and that oliver. the oliver is smaller than the 450 and about the same size as the 530 case. its definatley not a 770 it looks exactly like a 1600 but looks smaller in the picture. a 1600 should be about the same size as the 450 maybe a little bigger. seeing this picture makes me feel good that people used to help each other out in time of trouble.
kkiowa
04-10-2007 04:20:22
Checkerboard grill on the 550 and 770 wasn't till 1963. It could have been a row crop utility model 1600 which were shorter. I've seen quite a few 1550 row crop utility models and think it was available on the 1600 also.
Don-Wi
04-10-2007 00:09:31
The 1600 only came in 1 size and didn't come out until 63. They did however give the 770 a checker board grill and square fenders like the 4 digits during that era, and the 770 was produced for quite some time after the 4 digits were in production. Not sure how big a Case 530 is, but if that's a smaller utility model it could be a 550 that you're seeing in the picture. They got a checkerboard grill later on too if I remember right, but I could very well be wrong on this.
Donovan from Wisconsin
rrlund
04-10-2007 06:47:28
 Re: model 1600 in reply to Don-Wi, 04-10-2007 00:09:31
I don't remember a 1600 utility either,but if it wasn't a 550 it could have been a David Brown built Oliver 500. They were a DB 850. If it could have possibly been 1963 or so it might have been the larger 600 which was a David Brown 950 (same as a 990). That would have larger than the 550 but smaller than the 770 or 1600.
