550 steering wheel removal?
SW3
04-07-2007 22:09:06
What is the best way to remove the steering wheel on my 550? Will a jaw type puller work?
Also, what is the small flat head machine screw for that is located on the front side of the steering post?
Thanks.
SW3
04-09-2007 15:53:23
 Got it,,thanks in reply to SW3, 04-07-2007 22:09:06
I used a 3 jaw puller, used a smaller nut to protect the top of the steering post. It came off fairly easily by putting gradual pressure on the puller, and tapping on the puller bolt with a hammer.
J. Mash
04-08-2007 13:14:19
 Re: 550 steering wheel removal? in reply to SW3, 04-07-2007 22:09:06
Cover your cowl and gages with wet cloth,beat plastic off steering wheel at the center. Loosen nut. Heat with good torch,pour a little water on splines. Do this two or three times, then lift up on wheel while someone taps on the spline shaft with a hammer. Careful not to damage splineshaft and nut.Be patient it may take a few tries. A Thanks to Jim Kline in Ohio for this info.
J Schwiebert
04-08-2007 05:41:00
In your assortment of pullers do you have a "bearing splitter"? If it was me I would put the splitter on the bottom side and then attach my leg type or jaw type puller to it. That way you have a better contact surface on the bottom. I remember asking my service rep that 45 plus years ago and I don't remember what he told me. Happy Easter! J.
