oliver 77 adj. valves??
t.r.y.
04-06-2007 06:50:36
Hello I completely rebuilt the motor in our old 77 and have about 25 hours run time on it. Adjusted the valves when put together and then again after it ran around 5 hours. and retorqued head. Still the valves are a little noises. I know the are solids but still sound noises. Should I use closer specs than the it manual uses?? thanks
J Schwiebert
04-06-2007 09:15:47
 Re: oliver 77 adj. valves?? in reply to t.r.y., 04-06-2007 06:50:36
Did you resurface the radius on the rocker arms. Maybe you just have one that is loose. Is this with the short or long oil feed tube? The ones with the short tube tend to run a little dryer than the longer tube. What did you set them at?
t.r.y.
04-06-2007 10:29:00
 Re: oliver 77 adj. valves?? in reply to J Schwiebert, 04-06-2007 09:15:47
hi J I did have the rocker tips resurfaced. I actually converted over to the long oil tube rocker asy. I don't have the book here in front of me but I think it was .016 and .010. thanks
J Schwiebert
04-06-2007 16:03:28
 Re: oliver 77 adj. valves?? in reply to t.r.y., 04-06-2007 10:29:00
You did do the intakes at 10 right?
t.r.y.
04-06-2007 18:15:32
 Re: oliver 77 adj. valves?? in reply to J Schwiebert, 04-06-2007 16:03:28
yes J I did. I'm a full time mechanic so I do know a little about this stuff but was hopeing that you would have an answer with your experience, thanks J
