Oliver 461 mounted cultivator
Mark 770
04-04-2007 12:53:43
I see there is a 461 cultivator in the paper. I was wondering if this is one that would mount on a 770 or if it fits on a newer 4 digit tractor. I would like a bit more info before I call on it.
herald
04-06-2007 08:10:09
 Re: Oliver 461 mounted cultivator in reply to Mark 770, 04-04-2007 12:53:43
What was the number of the pipe style Oliver cultivator?
dboll
04-05-2007 12:52:18
640 will fit from a super 77 to a 1955, maybe others.
SherryS
04-05-2007 06:56:55
The 461 is s 6-row cultivator designed for close vegetable cultivation. It was basically the same tool bar as the 441 and could easily be converted for row crop use. You'd probably have to see it to know what it's set up for but it was designed for vegetables. It was designed to go on the S66, S77, S88, 770 and 880.
dad's88
04-04-2007 20:26:12
I'm thinking that IH had a 461 cultivator. Any IH guys tuned in that can confirm that?
1965 Oliver 1650
04-04-2007 18:51:10
I think you must mean a Model 640?? I have a model 640 and I believe that it fits a 77 through a 880 series. They might be adaptable to fit the 4 digit series, that I dont know for sure.
oliver fan
04-04-2007 16:30:59
The first thing you need to do is find out what brand of cultivator it is. Oliver built the 600 and 700 series cultivators. I have never see or heard of a Oliver 400 series of row crop cultivators.
AB
04-04-2007 20:56:38
 Re: Oliver 461 mounted cultivator in reply to oliver fan, 04-04-2007 16:30:59
Indeed they did make a 400 series. They made a 420 two row, 440 four row wide, and 441 four row narrow. If I was guessing I"d say the one he"s talking about is a 641 model though.
dad's88
04-04-2007 20:22:58
The 400 series was the first of the new style bolt on cultivators made to fit the Super series. I'll bet you have some literature on it too.
oliver fan
04-05-2007 07:26:18
 Re: Oliver 461 mounted cultivator in reply to dad's88, 04-04-2007 20:22:58
I was wrong and you are correct, Oliver did build a 400 series cultivator for a few years. After I posted that answer I knew something was wrong, but didn't give it much thought until your post.
I will not say where I had my head when I answered the question yesterday, but I will say what I was thinking. And it all has to do with green paint once again.
In the early 80's I had a Oliver tractor that I wanted a cultivator for. In the area farm paper was listed a Oliver cultivator for sale. I went to see it, and I knew right away that it wasn't an Oliver, and I didn't think it was a John Deere either, even though it was painted green, and the paint was orginal. The owner though it was a Oliver, but after I talked to him awhile he changed his mind. The owner and I then went over that cultivator almost with a fine tooth comb and discovered the teeth were what we thought to be orginal. The teeth had the Case eagle imprint on the backside. After I came home I did some checking, and found out that in the 40's and 50's Case had painted their cultivators as well as their tillage tools green. I also know Case built their own 400 series cultivators, and John Deere also built their own 400 series cultivators. That is why I said in my orginal post that he should find out what brand the cultivator is, because I knew Oliver didn't build a cultivator with the 461 designation.
Sorry for any wrong information. I would have been be better off if I had looked up the information instead of trying to go from memory.
dad's88
04-05-2007 15:44:44
 Re: Oliver 461 mounted cultivator in reply to oliver fan, 04-05-2007 07:26:18
Heck, half the time I can't remember what I did yesterday, and I'm only forty- er....um..... five! Did you get your goodies from Chris yet? You're gonna like it!
Mark 770
04-04-2007 19:04:58
I'm sure it's probably an Oliver cultivator. Most likely he's got the # wrong or the paper misprinted the #. I'll find out shortly. I knew the 600 series would fit but I was unfamiliar with this #. As a whole lot of cultivators were built under varying series #s I wanted to make sure this wasn't one of them. Thanks.
