Oliver OC3 ?
Erikoc3
04-03-2007 17:48:28
I have a 40"s Oliver OC3 that has ran fine for 5 years and it sat out this past winter. It starts fine but the clutch is not working. I can start it when its in gear and it moves, but once I pull it out, I cant get it back in gear. I cant get the clutch to break free. Does anyone have any ideas how I can break it loose. I dont know anything about it. Someone said it may need oil and I found a weird little cap on a wire right above the clutch. Not sure what is is. Any suggestions will help. Thanks
old
04-03-2007 19:45:30
 Re: Oliver OC3 ? in reply to Erikoc3, 04-03-2007 17:48:28
Most likely the clutch disc has rusted to the flywheel. First thing I would do is block the pedal down some how and let it sit a few days. If that doesn't work start it in as high a gear as you can and with your foot on the pedal take it for a drive. Hit the brakes off and on a lot, just make sure your out in the open becuase it could be hard to stop. I've seen that happen on almost all brands of tractors and most of the time they will pop loose if you drive them all enough with the pedal held down
