Oliver 1600 carb adjustment
landlord7012
04-02-2007 15:34:03
Could someone tell me the number of turns required to adjust the small and large jets on a 1963 Oliver 1600 (Marvel-Schebler carb)
Thanks in advance!
ll
putz54143
04-02-2007 16:34:27
 Re: Oliver 1600 carb adjustment in reply to landlord7012, 04-02-2007 15:34:03
my 1800b was 1 1/2 small and 3 on the big one
j meyer
04-02-2007 18:30:39
 Re: Oliver 1600 carb adjustment in reply to putz54143, 04-02-2007 16:34:27
1800 would have a different carb.
j meyer
04-02-2007 16:00:59
Turn them all the way down so the seat and turn them out 1 and a half turns. Run tractor and see how well you got your pre-sets. Adjust as needed (my 1650 was set dead on with the presets)
landlord7012
04-02-2007 18:42:34
 Re: Oliver 1600 carb adjustment in reply to j meyer, 04-02-2007 16:00:59
Before I removed them the small jet was 1 3/4 turns and large was 2 1/8. Thing is I cleaned a lot of rust and deposits out of the bowl, especially the angled cross holes near the drain plug and main jet. The tractor always did run rich until real recently it started to stumble and die until you choked it halfway so I knew I had to clean the carb.
Thanks again,
ll
