OLIVER 99 6 cylinder diesel
Dave J.
04-01-2007 17:02:59
Can someone tell how many diferent 6 cy.engines (OLIVER) that will bolt up in my "1953" Oliver "99" Also can you tell me where I could get my Bosh Inj. pump rebuilt? I'm particurly interested in what late model tractor--engine,that will fit right up to clutch shaft,or at least up to the center coupling.
ejr-IA.
04-02-2007 21:49:09
 Re: OLIVER 99 6 cylinder diesel in reply to Dave J., 04-01-2007 17:02:59
You didnt get a answer to one of your questions on what motors will fit.You have a 302 It is the longer block so I think you could use a 1800c,1750 and that would give you a rosa master pump.These should fit with very little modifcation.
Dave J
04-03-2007 16:56:40
 Re: OLIVER 99 6 cylinder diesel in reply to ejr-IA., 04-02-2007 21:49:09
Thanks... I thought I could use a later model, just was not sure which one 1750 or 1800 motors should be much more available..What are there---CUBES ?
ejr-:IA.
04-03-2007 19:03:10
 Re: OLIVER 99 6 cylinder diesel in reply to Dave J, 04-03-2007 16:56:40
310 cid
J Schwiebert
04-02-2007 04:24:31
Seal kit is probably $60.00. You can put that in yourself.
dad's88
04-01-2007 20:53:06
Are you sure you want to do an engine swap? Not many 53 model 99 6cyl 4 speed were built (less than 1000) and many of those were exported. I know engine parts for these are hard to get though.
rrlund
04-02-2007 11:01:57
 Re: OLIVER 99 6 cylinder diesel in reply to dad's88, 04-01-2007 20:53:06
I'll second that! If you don't want to fix it right,sell it to somebody who will and buy something else. You've got yourself a pretty valuable tractor there.
Dave J.
04-02-2007 03:57:30
 Re: OLIVER 99 6 cyl. BOSH PUMP REB. in reply to dad's88, 04-01-2007 20:53:06
I'd seen in a recent issue of one of the "OLIVER" magazines, someone that said they rebuild Bosh inj. pumps, I just can't seem to put my hands on that issue. Can someone help? Maybe post the name & -#. Thanks Dave
AB
04-02-2007 05:16:54
 Re: OLIVER 99 6 cyl. BOSH PUMP REB. in reply to Dave J., 04-02-2007 03:57:30
Central Fuel Injection Service Co 2403 Murray Rd Estherville Iowa USA 712.362.4200
dad's88
04-03-2007 10:01:23
 Re: OLIVER 99 6 cyl. BOSH PUMP REB. in reply to AB, 04-02-2007 05:16:54
AB gave you a good source as they do my work now also. They seem to be very knowledgeable and concerned. I'm sort of fussy with my stuff.
J Schwiebert
04-02-2007 04:23:00
This week keep your money in your pocket, Has this tractor set and then someone tried to start it? Did you check to see if the metering sleeve moved by using a small screw driver? How much money do you want to put in the pump? I am gone untill late late Thursday night. Send me a phone number or e-mail on the hpoca form. All is not lost yet. We probably had 250 plus Oliver six cylinder diesels we serviced and never had a PSB to a pump shop. If I don't know I know a good friend who did run a diesel shop when they were a Bosch service center.
J Schwiebert
04-01-2007 18:07:30
First dumb question: What is the matter with your Bosch pump? Also I might not answer you till next weekend as I leave in the morning ona business trip. J.
Dave J.
04-01-2007 18:12:36
 Re: OLIVER 99 6 cylinder diesel in reply to J Schwiebert, 04-01-2007 18:07:30
I have fuel to the pump---guy I bought trator from said the pump needs seals--no fuel getting to injecters.
