880 diesel starting
kwf
04-01-2007 08:34:49
Just bought a 880 diesel. Temp is 70-80 degrees. Have to ether it to start. It runs terrific with no smoke and lots of power. Shut it off wait few minutes it will start right back up. Wait say 30 minutes have to ether it again. Any suggestions, worn out pump, low compression, need to advance timing? The heater is not working that is my first objective, but still at these temps should fire right up I would think.
thanks
J Schwiebert
04-01-2007 16:13:01
 Re: 880 diesel starting in reply to kwf, 04-01-2007 08:34:49
If it starts when it is hot you head in the injection pump is good. Check transfer pump pressure. If it is good go for compression probably a minimum of 100 psi low.
dad's88
04-01-2007 13:41:14
See page 7 under post titled "SUPER 88 D". About half way or more down the page.
rrlund
04-01-2007 15:01:26
 Re: 880 diesel starting in reply to dad's88, 04-01-2007 13:41:14
Is that the one about the primary fuel pump Blaine? I'd about bet that that's the problem.
dad's88
04-01-2007 15:22:04
 Re: 880 diesel starting in reply to rrlund, 04-01-2007 15:01:26
Yep, lots of good info on that topic. Covers just about anything it could be and we don't have to re-type it all! A real bonus for a hunt and peck guy like myself!!!
Tramway Guy
04-01-2007 10:10:47
Do you get white smoke when you try it without ether?
If you do, your pump is probably ok...and you would be looking at a compression or timing issue, but more likely compression.
Tramway Guy
04-01-2007 10:10:44
