PTO set screw-Help!
David Scotton
03-29-2007 18:34:34
I have done a z split on my Oliver 550 to replace the pto clutch discs. Everything was going great until it came time to remove the pto clutch assembly. Apparently there is a hex set screw that has to be removed to slide the assembly off the shaft. The hex set screw is directly below the housing for the lock pin. Since the whole assembly turns as a unit I can not get to the set screw with an allen wrench to remove it. Any and all suggestions appreciated.
Thanks David
kent
03-30-2007 05:55:44
 Re: PTO set screw-Help! in reply to David Scotton, 03-29-2007 18:34:34
Loosen the clutch adjustment & you can turn the outer part---HTH
Kent
