Oliver88 serial no.
M Peters
03-27-2007 21:29:11
I have an Oliver 88 tractor, and the serial number tag got tore off years back. this was my grandfathers tractor and I have no record of its history,except Dad figures it got tore off clearing land years back. Serial no. tag was on upper transmission front right hand side. Is ther another spot to identify the serial number? Engine serial number is G4 789213. Dad believes it is a 1950 model. any advise in which I could get the serial number? any advice would be greatly appreciated. Thanks
RJH
03-28-2007 16:18:27
 Re: Oliver88 serial no. in reply to M Peters, 03-27-2007 21:29:11
When we restored a 1954 66 standard industrial, we found the serial number stamped on the frame under where the dash mounts on the frame, not visable till the dash was removed, never found one in this spot before.
dad's88
03-28-2007 15:20:20
I'm not aware of the tractor S/N being stamped behind the starter. Unfortunately the build cards only go back to the start of the Super series, otherwise your engine S/N could have been matched to your tractor S/N. Would have required some diging though. Do you have the original owners manual? Sometimes the dealer filled the delivery pages out at the front of the book. If your lucky it might be there or maybe it was written on the cover.
old
03-28-2007 07:51:23
From what I have been told there is still a serail number on it. It will be behind the starter, I don't know if you can see it with the starter on or not.
M Peters
03-28-2007 20:44:39
 Re: Oliver88 serial no. in reply to old, 03-28-2007 07:51:23
I have removed the starter, but I cannot find any serial number or numbers in the casting. Would this number be on the engine, or on the frame? Thanks.
old
03-28-2007 21:07:58
 Re: Oliver88 serial no. in reply to M Peters, 03-28-2007 20:44:39
should be on the block
rrlund
03-28-2007 07:12:39
If the tag was on the side,it would be prior to the fall of 1951. There will be a casting code up on the bottom of the rear end housing to tell when it was cast. The first number will be the month,second will be the day,last is the last number of the year. For example,10 3 1 would be October 3 1951. I think that's right anyway. That won't be the exact day of manufacture of the tractor,but fairly close.
M Peters
03-29-2007 11:19:16
 Re: Oliver88 serial no. in reply to rrlund, 03-28-2007 07:12:39
I checked closer on the block behind the starter.I noticed a small rectanguler shaped mark on the casting about 1/2 by 2 inch. I don't know if this was a tag or stamp in casting but if it is a stamp in casting it is very deteriorated and probably not able to read. if a tag it is missing. I did find a manufacture date in casting as was stated in our discussion at upper bottom of rear axle housing. It says: 10 1 8 49 Thanks for that tip but as far as ser.# I may have to check under dash on frame.
