white 2-70 hyd.leak
tomupton
03-24-2007 14:39:57
Just bought a 2-70 but it leaks oil out of the hyd resovoir allmost as fast as you put it in. I am assuming it leaks into the trans. as after I filled it looked like it was running out the input shaft?(oil running out from between the chain coupling)Any one have any experience on what is involved to repair? Could it just be a bad seal on the pump shaft ? For anyones interest the tractors I went to buy at this sale where a pair of 660 diesels, one with narrow front and cultivators, other with wide adjustable front.Both running o/k and half decent original shape. Unfortunately for me they sold too high for my pocketbook. If I heard right the narrow front was $5200 and the wide was 4600 (not sure of the exact final bid as I had to force myself to turn away or I might have been convinced to keep bidding!! )
Larry from md
03-24-2007 16:46:01
 Re: white 2-70 hyd.leak in reply to tomupton, 03-24-2007 14:39:57
The hydrolic pan could be cracked or have a hole in it. Or the seal. Anyway you need to remove the whole thing and find whats wrong. The pan will leak without the engine running.
Fern(Mi)
03-25-2007 11:10:47
 Re: white 2-70 hyd.leak in reply to Larry from md, 03-24-2007 16:46:01
Unfamiliar with this tractor, is the bicycle chain long drive shaft, rock shaft housing same or similar the 50 series Ollie�s.
If so it may be the draft control pie seal thru the bottom center hydraulic reservoir? In any case the rock shaft assembly needs to come off. Wow! All the oil galleries have to be over full, wrong or contaminated oils! Relatively clean worth saving for drive chains lubricating oil.
Not to bad a job using a chain fall.
Have fun and good luck.
Fernan
