770 oliver block numbers
Ed Hodge
03-21-2007 17:36:09
right side front - 60900
left rear - 185220-F 104306-A
left mid - 1253
can someone tell me thay meen????
B A Star
03-22-2007 21:48:05
 Re: 770 oliver block numbers in reply to Ed Hodge, 03-21-2007 17:36:09
Guys, the 1-64 stamped in the machined surface where the fuel tank mounts is the month that the engine was assembled at Waukesha
dad's88
03-21-2007 21:35:10
All of the above (below) and since the number under the fuel tank support is 1-1964 I'm gonna say the block was cast on DEC 5, 1963.
J Schwiebert
03-21-2007 18:34:20
The most interesting one is the right side front. Is it a stamped number on a cast flange. The other 3 deal with the casting. 1253 is the casting date. The 104 is the Oliver Casting number. The 185 is the Waukesha casting number.
J Schwiebert
03-22-2007 04:02:54
 Re: 770 oliver block numbers in reply to J Schwiebert, 03-21-2007 18:34:20
Memory is starting to fade here and I got my little book out this morning. It is a 1964 tractor without seeing the serial number. The closest engine number I have for a tractor that was sold where I was employed to that is 59455 which was on an 1800 delivered in late spring/early summer of 64. I was guessing it was the engine number as well but could not remember that they were that high of a number that early.J
Ed Hodge
03-21-2007 18:40:48
yes it is a stamped number but looks like the factery did this
i found a nuther number behind the gas tank mount 1 - 1964 my gess that the year of the motor
SherryS
03-21-2007 18:37:46
I would venture to say that the number on the right front is the stamped Waukesha serial number for that engine.
